We are currently using AutoCAD and have AutoPlant and ProStructures models that we are referencing.
I am not able to access the downloads area for the correct ProStructures Object Enablers; I have been able to locate the AutoPlant Object Enablers for download in Bentley Communities.
We are using AutoCAD 2016. How can I download the object enablers in order to properly view the Objects in AutoCAD.
Is it possible to address this so future object enablers are available as basic access when a person creates a login?
Follow the instructions for downloading software in the link below. Search for ProStructures for AutoCAD and the object enablers will be in the list. Also, there is currently a discussion about making it easier for users to access and download free applications.
Software Download Instructions
Steve
How are these older Object Enablers found now? They don't appear to be available from the Select download page, and I don't see a link to the old download page.
Regards,Sandip KarProduct Engineer - Bentley Systems
Hello Sandip,
I found the OE for AutoCAD 2016 in the Files section of this forum and that worked. The objects were visible in AutoCAD.
I then tried to open the 2013 file format DWG file in MicroStation V8i - and it fails to open (which had been the primary issue that started me looking for OE's).
Deepak found the MicroStation plug-in for ProStructures for me, so I installed that.
The DWG file will still not open in MicroStation.
We have found a work-around and no-longer need to pursue this.
Thank you for your reply.
Michael
