Hello
Is it posibble to define drawing name (in*.frm file) that will include group area class name
I'm using detail center express and single sheet output (one group on one drawing)
Now my drawing name is ObjectNameSymbol & GroupPositionNumberSymbol
I wolud like to use area class name instead ObjectNameSymbol
BR
Adam
Hello AMA,
Thanks for posting your queries in Bentley Community Forum.
Could you please provide any detail or sample in which format you want the drawing name so that we can give you better solution.
Thank you.
Regards,Sandip Kar
Regards,Sandip KarProduct Engineer - Bentley Systems
Hello Sandip
Right now i do like this:
I change group name to which I want. for ex. "beam" or "column"
then I use positioning to define position number - for ex. "B5,B6...etc"
Now, through detail center express I generate single sheet drawings - and drawing name is "beam B6"
Drawing name, is combination of ObjectNameSymbol and GroupPositionNumberSymbol (see attachment)
I would like to use partfamilies now. Is is possible to use part family name instead of ObjectNameSymbol in drawing name creation ?
Adam Mastalerz
Hello Ama,
Thanks for explanation your requirement.
The Area Class can be called out in drawing name. Please follow the below Steps:
3. Come back two step left by clicking back button to Single Sheet output page. Click browse button of Border Frame File to open the ".frm" files. Open the file in notepad in which you want to modify. Now do the below changes in that file.
Change the file and save.
4. Now create the drawings. Drawing name will come as LRA_B6.
Please note that for multiple areas you need to change the name in User variable tab.
Try this. You will get the result.
Please let us know if you come across any further issue
Looking forward to your update.
Answer Verified By: Johannes Michalowsky
Have your issue been resolved?We are looking forward to your update.
Thank you.Regards,Sandip Kar
