Hello!
I am having an issue trying to import a DSTV STP file into Prostructures. It seems like the profiles are identified correctly, but the length of each member is being scaled way up. I have tried multiple mapping tables, and even tried both DSTC and CIS format for the STP file. Always the same result. Is there something I can tweak in the import settings to get a better result?? (all attached files are imperial units, and I am running Prostructures SS5 for AutoCAD). Stp export files are attached. Thanks in advance for your help!
honey.zip
Jesse
5810.honey.zip
you need to set an imperial template dwt, one Honey is CIS2 format other one was DSTV format please chose accordingly the import.
https://communities.bentley.com/products/prostructures/w/structural_drafting_and_detailing__wiki/27525/importexport-file-formats
best results you will get via SDNF.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Thank you Johannes,
I will try that and mark as answer once I have verified.
