Prostructures 使用抗剪栓钉布置命令,无法生成剪力钉,缺乏数据库,怎么办
dowels can be placed via
or
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
型钢抗剪栓钉可以调用预定义栓钉尺寸,预定义块和数据库三种方式实现,如下图是通过第一种方法在bolting页面输入具体栓钉尺寸后点击型钢自动完成抗剪栓钉的布置的,并可以存成模板以备复用。如还有问题请email:runsong.lin@bentley.com 感谢你的支持!
The headed studs with beam can be placed as three methods: dimension, block and database. I just make an example with dimension input. Any more questions, please email to me: Runsong.lin@bentley.com Thanks
