Hi
I am exporting DGN's to DWG's but although the units in the DGN are set to millimeters, when the export is completed, the units in the DWG have changed to inches.
I have changed the unit tab in Export, DWG, Options, Basic, Units to millimeters but still when the export is done, the unit is inches
Many thanks for raising the issue.
we are investigating the issue and will come back to you.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
See following Wiki for the solution
https://communities.bentley.com/products/prostructures/w/structural_drafting_and_detailing__wiki/37867/converting-dgn-to-dwg-gives-wrong-unit
