Dear All,
In ProStructures how I can model the beam by many line was selected?
Johannes Michalowsky
Please help me to solve this issue
Hi Nguyen Duc Hoa,
Thanks for posting your query in Bentley Community Forum.
As you said, what we understood, you want to model Beams in multiple Workframe lines at a time. Please correct me if we are wrong.
If so then you can do use the tool in ProSteel shape.
We have also attached a short video to explain, how to insert beams in multiple Workframe lines at a time.
We hope this will answer your question.
Please let us know if you have further clarification
Regards,Sandip Kar
Regards,Sandip KarProduct Engineer - Bentley Systems
Dear Sandip Kar,
In this case can not use workplane, please see my screenshot for more detail
Hi Hoa,
If you have multiple lines and you want to model beams along all the lines, you can use the following tool in ProSteel Shape.
We believe, this will solve your issue. Looking forward to your update.
Regards,Sandip kar
Thanks Sandip Kar
It work fine.
