Hello I am using Prostructures SS6 R1 for AutoCAD (08.11.11.161).
We are experiencing long waits (about 10 min) any time a detail block is being created or updated from the detail center. AutoCAD goes to not responding, and after a few mins I see a progress bar start on the bottom of AutoCAD that says it is removing parts. It is not network related as I tested with both model and 2d drawing on my local drive and saw the same result. Anyone have an idea what could be causing this? I will attach the model (detail styles are loaded into model) and drawing here for your review. Thanks for any help!
examples.zip
Hello Jwolfe,
Thanks for posting your query in Bentley Community Forum.
We will look into your issue and get back to you soon.
Regards,Sandip Kar
Regards,Sandip KarProduct Engineer - Bentley Systems
Any results???
There are no unusual process times with your model here. But there are references we don´t have. It could be that the references influence the process.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Answer Verified By: jwolfe
