I can't able to fill my rebar in my Prostructure drawings even though I already tick the check box option for "full size" & "filled" in the bar ranged display.
Anybody can help what I miss out, previously in V8i I don't have problem about it.
Than you.
Thanks for posting your query in Bentley Community Forum.
Yes you are right. There is a little change in CE Version.
You need to set the Visual Display Style as Filed Hidden Line along with the option Filled and Full Size to be switched on in Main Bar Attributes.
Please note that after doing you also need to do Save Settings to remain it as well what you changed, otherwise you will loose all your changes.
We believe you have got your answered now.
Please let us know if you need further assistance.
Regards,Sandip Kar
Regards,Sandip KarProduct Engineer - Bentley Systems
Answer Verified By: IronMaxSteel
Thank you Sandip.
