Could you please help me what does I miss out, I cant able to see the hatch on my concrete section using Dynamic Views.
Previously V8i just assigned the concrete element to a proconcrete template, then make sure the display visual was in cut, then immediately hatch created in the dynamic view 2d drawings,
For CE prostructure, I try the same procedure in the V8i but still count not get the result I wanted.
Thank you in advanced.
It would be kind if you can upload your file
There are two options for sharing your model files on BE Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment via insert. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
communities.bentley.com/.../bentleysecurefilesupload.aspxIf you upload the model files to Sharefile, please post a message here so we know they are available
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hi Johannes,
Here is the sample trial testing.
Previously in V8i I will just assign the concrete element to concrete template, immediately when I do section it generate the hatch pattern of it.
Trial 1.dgn
