So a rather simple file of mine went from roughly 200kb to around 15mb.... and I don't know why? I tried pruge, overkill, audit... to no avail... perhaps someone has some advice on this matter. It is taking hours to push out the most simple drawings...
I'm uploading the earlier file (200kb) and the same file a week later (14mb) for analysis.
Bernie Malaky
YA Metals
Many thanks, just your upload is missing.
There are two options for sharing your model files on BE Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment via insert. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
communities.bentley.com/.../bentleysecurefilesupload.aspxIf you upload the model files to Sharefile, please post a message here so we know they are available
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
I'm not succeeding in uploading!!!
I have uploading to the secure file server twice with this pages URL as a link.
I have also tried uploading via link... to no avail.... ideas? prehaps I can send a dropbox link?
I'm not sure why, but the file(s) will not upload for me. I instead am attaching a link to the file in Dropbox. Please let me know what you think.
We have resorted to making shop drawings by hand because the file is too large to process drawings in express.
Thanks.
Bernie
www.dropbox.com/.../From small to Big.zip
y did reference something in which can´t be deleted right now.
PERGULA 1-7 02.07.18a.dwg
i did export import via psb to clean itup
see also maybe
https://communities.bentley.com/products/prostructures/f/subforum-prostructures/123102/help-annoying-problem-with-2d-views/373494#373494
