I have a problem with visibility of my position flags.
They are visible as long as they are only in the preview of Detail View, but when im creating 2D drawing from the views, the positionflags disappears.
How it looks in preview:
How it looks like, when a 2D drawing is created:
What's the matter?
Im working on ProStructures v8i SELECTseries 8.
Kind regards,
Konrad.
Hi Konrad,
Thanks for posting your query in Bentley Community Forum.
This should not happen.
Could you please share your model so that we can see and give you the solution?
Regards,Sandip Kar
Regards,Sandip KarProduct Engineer - Bentley Systems
Please ensure that all layers will be turn on in your drawing sheet, Otherwise try to insert in a new sheet.
Hope it will works for you.
Thank you
Best Regards,
P.Prabhakaran
Here is my Model.
All layers are turned on. It doesn't matter if I insert block into a model, a drawing or a sheet. The flag positions aren't visible.
Issue still occurs. Another model with styles and templates:
Issue2
Another problem occurs when im trying to make drawings throguh DC Express. Singleparts do fine, but when im trying to insert group drawings on multiple sheets it doesn't do anything except creating new detail blocks. I can see in DC Express that it adjusts size of the sheet and make all detailing. In report file i can read that detail blocks couldnt be either read or inserted. It also do fine when im trying to insert multiple groups on one sheet. You can try it out using model and styles linked above.
