PS_Analysis
Dear all,
In prostrctures what is the use of PS Analysis tool.
How can we use the tools effectively.
kindly explain if anybody knows
Thanks in Advance
  • Hello Prabhakaran,
    Thanks for posting this query in Bentley Community Forum.
    Analysis View is used to display analysis effective lines of selected structural objects. It is possible to modify the effective lines manually by using the offered options of this function or by modifying them via handles.
    Analysis display allows you to control and work on the effective static analysis lines of the shapes to get an optimum output for translation to static analysis programs. From the individual interfaces, you can force the output of analysis display. The effective lines defined by you are outputted instead of the center lines of the shapes.
    If no modifications are made here, the effective lines correspond to center lines. This tool allows you to modify the effective lines independently of the insertion of a shape to balance for instance, eccentricities, if these have no importance for calculation or to close open nodes.
    You will get detail information in help file.
    Sandip Kar
    Product(s): ProStructures CONNECT Edition Version(s): CONNECT Edition Environment: N/A Area: Help File Subarea: Help Original Author Sandip…
    Sandip Kar
    Product Engineer - Bentley Systems
    Answer Verified By: Prabhakaran.P
  • When this button is clicked "1. ", the program tries to connect the effective static analysis lines automatically to create a closed system. If the effective lines are situated in a common plane, they are extended to each other and a node is symbolically represented as a ball. At the same time, the ends adopt the same colour as the center part of the line to display a closed connection. Please note, that the penetrating lines are not divided at the nodes. You can force this division later during export.
    When this button is clicked "2.", the program verifies whether a connection to neighbouring parts or an open end exists. The represented colour will be modified accordingly. “Red” signifies that there is an open end and “green” means that this end is connected with a neighbouring part.
    The difference between this function and the function 'Automatic' is, that here the program only checks and the display is updated where as the function 'Automatic' tries to create a connection and when doing this can also modify the effective line.
    If this button is clicked "3.", the components in question are connected with each other by means of a manual link. For this purpose you have to select the components afterwards.
    The main part of the manual connection keeps its position; the connected parts are related to this main part so that their effective lines can e.g. be positioned diagonally towards it. A node will be created automatically. A manual link does not have any further meaning. It only serves for creation of intended connections. On one hand, these connections are used in this function for the definition of nodes. On the other hand, they allow dimensioning of system lines at detailing.
    It allows to optimize the output for the export to analysis products
    Bentley Structural YouTube Channel
    Bentley Technical Support
    Johannes Michalowsky
    User Success Support - Bentley Systems
    ServiceRequest Manager
  • Dear Sandip,
    Thanks for your answer.
    Best Regards,
    P.Prabhakaran
  • Dear Johannes.
    Thanks for your brief answer.
    I will go through it.
    Best Regards,
    P.Prabhakaran
