I am trying to create a report showing the assembly member/number with the respective parts/fittings. When I select a construction group list, run the report, the assembly shows the quantity correct but the parts listed only lists for only one assembly/group. Please refer to the screenshot below, GR17, we have 2 of this, but the fittings/parts listed is only for one assembly/group. How do we make those parts'quantity be listed as a total for the total number of assembly/groups.
Hi Brian,
You are right. It is not working as per the requirement. And even the older variable which you mentioned, that also not working. We need to further investigate and may be should file an Enhancement.
We will notify you whatever solution we achieve.
Thank you for your cooperation.
Regards,Sandip Kar
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Guys,
Is there a way we can assign the quantity of the GROUP to a variable so we can use that variable as a multiplier to the PARTS quantity? Can anyone please provide some help on this. Thanks in advance.
Hi Sandip,
can you please clarify what you really meant with this?
Sandip Kar said: if there is any possibility
Please be advised that this is possible as this was working in ProSteel+Acad.
Apologies for being a pest here but it's just this upgrades/updates seems to have more backwards as well. . .
We can understand your point and you are right. We have tried in many ways to achieve this. I will report a Defect on this and will let you know.
Thank you.
