Dear all,
In my 3D model unfortunately my beams positions are drawn wrongly in the whole model.
The blue line represents below in the attached picture normally it goes upwards.
how can I find all the beams which are in wrong position, and how can I rectify it in the 3D Model which are already done.
Is there any tool to identify the wrong position of the beams??
If we have kindly suggest.
Thanks in Advance.
P.Prabhakaran
You can mirror the beams. And turn them 180 degrees via the dialog too.
This not a "wrong" position generally seen, if all, the blue line goes upwards, you can turn them 180 degrees.
Why do you need another alignment ? Is it because of detailing results ?
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Dear Johannes,
yes in sometimes some beams when I extract 2D the output will be mirror.
Best Regards,
This happens when using Reference view individual per part.
If using global views this will not happen.
Answer Verified By: Prabhakaran.P
