Hi I am using prostructure Detail Centre, trying to produce 2d drawing from a model. Int the parts Tab some parts are grey and Not processing or able to insert to views tab even after assigned style. Could anyone assist and advice please. Thanks in advance.
Hello Dino,Thanks for posting your query over Bentley Communities Forum.In regards to your issue, can you please attach your model so that we can check and resolve the same.Regards,Alistair Lobo
the color coding tells you in which state the details are for processing
what is the meaning of color coding in 2d detail centre
Grey means the parts have not been processed. The reason why this could be the case, can be various, like a restricted style.
As said below, we will need your model for a full conclusion on the issue.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hi Jahannes and Alistair,
Thank you for the response, I managed to determine the cause and have resolve the issue.
It came down to not properly applying positioning numbers.
Where the model had identical position numbers.
Detail centre would identify the parts as similar and would not process it to the views tab.
Answer Verified By: Dino Crisostomo
