I have created my Group Drawing, everything is Positioned and Marked.
Hello Andrew,Thanks for posting your query over the Bentley Communities Forum.In response to your issue, on trying to reproduce this, we get correct results.That is, in the dialog box, on selecting '3D Elements' the partlist is created correctly.Hence, we request you to share your model and also the version details of your application,so that we can assist you on the same.Regards,Alistair Lobo
If the elements have no 3D information anymore (only 2D lines used in detail style) you need to use 2D Position flags. It needs to be a Group existing to get a Group part list.
Best regards
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Thank you Johannes, I deselected "As true 2D Lines" in the Edit Styles-> Common->Display dialog. And my "Drawing Parts List" now works like a charm.
