Hi Guy,
In ProStructures how to import CAD drawing to elevation view and in elevation view how to show label of axis
Hi Hoa,
Thanks for posting this query in Bentley Community Forum.
If you want to import CAD drawing in Elevation view can be done via Reference. Via reference you can attach anything in the drawing.
This can be found under Steel > Home >Common Tools > References
Regarding your second question I will suggest you to go through the below Wiki link
Regards,Sandip KarProduct Engineer - Bentley Systems
Thanks Sanip Kar,
Please see my video I use Reference but my dwg file not align to elevation view
In that case you can easily align via using move command.
It depends where your active ACS is when you insert the Drawing, also you can move the reference via dialog in X,Y,Z and rotate.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Can you make short video demo for this
