Hello
We have big problems when we move on new version of PS 08.11.11.207 from 08.11.11.87.
The laptops and system is brand new. Win 10 and autocad 2017 with SP1. Also AecModeler.dbx file was changed. If we open the model in new system all pipe elbows it looks like donuts.
If we create on this model any new they looks the same. I remeber that in Autocad 2015 was the same problem but service pack from autodesk resolved that.
Do you have idea what we can do right now?? I have very big constructions and much more handrails. Please, help us.
Also export to psb and import again doesn't work.
And as said, it is going to be addressed for the upcoming versions.
This is a recommendation only, your complete Model can also be on 0,0, and than referenced in, but of course it depends on your workflow.
We will contact you directly for further clarification in any case.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
The problem stiil existling and not be resolved. I have 15 people working in different projects, what can sholud do??
Maybe Bentley once pay for the delayed steelwork and I told you, I can't move models to point 0. The others companies who working with me, will be very confused when we do that and ofcourse they will want money for that. I know, this is recommendation only, but this not resolve my problem.
It does not mean, in this case that, you deliver the drawing with your model at 0,0. It means you deliver the drawings or models referenced in into a master layout with the correct coordinates given by the reference and deliver this complete layout. This is a quite standard practice for some of our clients for geo referenced models for example which are many kilometers away from 0 for this purpose.
This is a quite common way for this kind of layout creation, but of course this is just a possibility to have a immediate working solution for the issue.
Hello Mr.Michalowsky
Sorry but I still waiting for solution. Your sugestion to move model to point 0,0 is not possible for me, because some other companies who working for me, will have be the problem with localization. From other site, we can't moved model because layouts come to us from our client and we must have the same zero point. However, I checked your suggestion and move models to point zero, just to be sure is that solve my problem. And...
You give me "solution" but...
You don't check that , becuse if we move models to point zero , others elements like bent plates or slot holes, if we generate 2d views, not are perfectly. Axis for holes stay in orginal places, also bent plates not to be seen properly.
Right now, we can't move. Who pay for that.?!Can we back to earlier version of PS? What will be happen with models? How we can do that?
The moved model was attached in the first reply. We did not have issues when detailing. We will contact you via Service request. The Model are backwards compatible with former version 8.11.11.132.
