Whats the procedure for submitting a broken drawing file.
That is to say, I created my model and then inserted the details into a second file via the Detail Center.
Now when I try to open the details drawing file I get a fatal error. *sigh
Not the first time this has happened on this station.
FATAL ERROR: Unhandled Access Violation Reading 0xffffffff Exception at c25da31dh
07/17/2019 at 11:06:35.920 Drawing: \\SBXXX\Company\Job\1550-1599\1562 Whitby\Drawings\Fabrication\(20190711) Moveable Partition\1562-REV00 (ALL FAB3 & FIN3 DRAWINGS).dwg-------------
AutoDesk
Product Version M.151.0.0 AutoCAD 2016.0.11
Bentley
ProStructures V8i (SELECTseries 6 R2 for AutoCAD) - Version 08.11.11.207 from Jul 11 2018
Hello Andrew,Thanks for posting your issue over the Bentley Communities Forum.In response to your query, at the moment we can not suggest a solution for this, as we will need to check your model first.Hence, can you please attach the same so that we can better investigate it.Regards,Alistair Lobo
1562-ER-REV00 (3D MODEL MOVABLE PARTITIONS).dwg1562-REV00 (ALL FAB3 & FIN3 DRAWINGS).dwg
Hi Andrew, Thanks for the swift revert. We will work on this and get back soon. Thanks & Regards,Alistair Lobo
Hello Andrew, We apologize for a delayed response.We have tested your file and have tried various methods, but it seems that the file is corrupted and beyond recovery.Thus, we suggest you to re generate the 2D drawings via the 2D Detail Center again.Regards, Alistair Lobo
