Dear all,
In my project I need to add the paint information in Part list and Dwg.
But unfortunately I got updates in drawing,See below refence picture
I update the information in Note 1 category.
But I am not able to update in the group partlist.
see referene below picture.
Kindly give your valuable feedbacks/suggestion.
Hi Prabhakaran,
Thanks for raising this point to Bentley Communities. We will work on this. In the meantime can you please share your file with the lst file you used for creating Partlist.
Regards,Sandip KarProduct Engineer - Bentley Systems
This can be achieved by editing your partlist definition.
In ProStructures Partlist when you go to Settings > Edit Partlist Definition, it will ask you to select your desired lst file and then it will open in Partlist Editor in new window.
Here you can customize your needed variable.
1. Double click in the report container which will open up the Table content of the partlist.
2. In Data line add a new variable "Note1" and also in the Header Line at the same position you can place Text as "Paint Note"
Then when you publish partlist you will get the partlist with paint note
I believe you will understand how to achieve this. If not then do let us know.
Have your issue been resolved with the provided solution?Looking forward to your update.
Dear Sandip,
Now only I have working on it.
If once update the solution,I will update you.
Thanks.
Best Regards,
P.Prabhakaran
