For some reason I cant edit the weld flag locations using the grip edit
I can move position flags by selecting the middle grip, but weld flags I cannot. I can move the weld symbol leader line or rotate the flag but not shift it.
This works normally fine in Update 3, can you please attach a drawing to replicate from our side ?
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hi Mike,
We have tested this issue in Update#4 and it is working. I could able to move the flags as desired location by just dragging the handle.Attached is a video for more clarification.
Regards,Sandip KarProduct Engineer - Bentley Systems
OK. I have tested further, problem is specifically with the weld flag styles migrated from V8i.
If I manually draw a flag in I also cannot move the weld flag ofter creation. The APC weld flags work as expected.
for some reason I cant upload the wsy style file
1234-A1-A3.dgn
Hallo Herr Michalowsky,
gibt es da ein Problem mit den Schweißnähten wenn ich ein Modell, dass in der V8i erstellt wurde in der Update 3 detaillieren will?
Das wäre fatal, wenn ich auf der Zeichnung die Schweißnähte, die aus dem Modell kommen nicht mehr bewegen kann.
Grüße
Jens Kießig
