About ProSteel Command Description
Dear Sir or Madam,
I'm using ProSteel for AutoCAD 2016. The snapshot shows help information from ProSteel about 'Cope Dialog'. My questions are as follows.
Q1:
The dialog contents are not matched with the help description exactly. I guess that the help information is not updated with the current ProSteel version. The information maybe was copied from the old versions and NOBODY checked it if it matched with current version. Should ProSteel assign the job to somebody inside the ProSteel development team when every new version release?
Q2:
Is there other any source, books or websites or PDFs, which may descript the ProSteel command in detail and it's better to give some examples?
Thank you in advance.
William Wu from Keywest
