I would like to know whether prosteel can be used to design a PEB warehouse. Will there be ready to use PEB sections available like tapered built up sections
Binesh lal
Hi Binesh, Thanks for posting your query over the Bentley Communities Forum. Addressing your query, we would like to convey that ProStructures can definitely model the PEB warehouse structures. You can certainly model tapered built-up sections in ProStructures and generate 2D drawings for the same. Please let us know if you have any other specific requirements so that we can assist your with the same. Regards, Alistair Lobo.
I have brought the prosteel licences and is unable to do the above referred modelling. Can you me guidance on the said matter ie . Modelling with built up Tapered section
Hi Binesh,
Can you please provide some images of the tapered section you are looking to model in ProSteel. Also, can you please send your contact details and time of availability so that we can discuss your requirement in more detail over a call. Waiting for your update.
Regards,Alistair Lobo
