Helle everibody.
Whe draw groups or single parts the flags are huge. How do fix this issue.
please, can you attach your DGN here, otherwise its difficult to predict or suggest any causes.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Dear sir Johanes Michalowsky.
Thank you for your email. I already resolved this issue.
Position >> flag definitions and in the checkbox size I changed the text size and work.
That I saw is that for being working in meters like the long unit I had been some difficulties.
The question now is, how to make for work in millimeters. Or in another way. How change the seed to work in millimeters.
I try in this way but if the seed is en meters I found some difficulties.File >> settings >> file design >> file settings >> working units
I always was prosteel under autocad bot now I am prosteel under microstation user and I not familiar whit microstation seems. If you can recommend any document to investigate about seeds in prosteel I will be very grateful.
P.D: The file is big and the plataform do not allow upload the file.
Best regardsJorge Hugo Correa
