In these challenging times when COVID-19 is imposing significant disruptions to day-to-day activities and affecting normal business flow, we at Bentley are committed to helping you transition from an office environment to working remotely or at home.
The following articles contain information to help you be successful with using Prosteel while working remotely or from home:
We welcome feedback, questions, and ideas on how we can serve you better in a remote work environment. Please share them in this thread. If you need technical assistance with using ProSteel at home, please start a new thread in this Forum.
Best Regards,Bentley Technical Support
I'm more confused than I was before reading all that.
Where is the "check out a license" button like every program other than Bentley stuff has?
Hi Michael, To check out a license, you can refer the below Wiki.
Also, if you are still facing an issue, please let us know so that we can assist you in resolving the same.
Regards, Alistair Lobo
Why does Bentley make everything so hard. Autocad is literally 2 clicks.
Checkout would be only needed if you are without Internet access for more than 7 days.
If you have CE Licensing like in the latest AutoCAD Version or any other CE Edition you can check out via the new Bentley Licensing tool
located in C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Bentley.Licensing.LicenseTools
If you use a shortcut its a direct call for the License Managment, just filter for your product you want to check out and execute checkout
The administrative tool to check out to specific machines by the Entitlement Management is explained here, you need this only if you are an Admin for many accounts
Bentley Structural YouTube Channel
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
