I am trying to find the Bentley Technical information that describes the creation of posts/panels for use into the Handrail tool to insert handrail by Block. Can someone point me in the right direction?
Hi Andrew,
You need to create blocks first to have your desired Posts as block and then you can fetch that block into the handrail tool. But there is doubt to work in inclined handrail.
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip,I'm just after the Bentley instructional pdf that describes this process with the creation of post blocks/what notes to put into the "Note 2" field as well as the description for DP point placement in fillings.I used to have a copy of this printed out, but can no longer find it, nor can I find it online.Thanks for you assistance.
We tried to reach you to investigate this issue. But you are not picking up the call, it may be you are busy or it is too late for you.
I will recommend you to raise this request via Service Request, because this is not possible to resolve in the Forum section.
So please raise a Service request on this so that we can work on this and can give you the solution.
In the online Help you find various Information on this functionality. For Example, for posts it needs to be a P in remark 2, and for handrails it needs to be a R in remark 2.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Thanks Johannes,This is the information I was looking for.I used to have a PDF version of these where the information was delivered differently, would you know where I can find that?
