Hi Fernando, Thanks for posting your query over the Bentley Communities Forum. In response to your query, I would like to inform you that, with the standard Truss commands available in ProSteel, you can model symmetric and un-symmetric trusses and joists; but the arch option is not currently available with this macro. However, you can still model this manually and achieve the configuration as in the screenshot you have attached. But if this is critical to your business and workflow and if these kind of structures affect your modelling and work extensively, we would be glad to know more about it and add this feature in our product. For this, can you please convey your contact details and time of availability so that we can discuss this in brief. Regards, Alistair Lobo
It would be possible to create this model in STAAD.Pro (geometry + properties), export it to ISM, and import the ISM file to ProSteel
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Thanks for the answer. I'm learning BIM, so this is a homework for my college studies (I'm using ProSteel student license). I chose this type of truss because it is widely used for big spans in my country (Brazil). I will try to model it mannualy. Thanks for the tip. The possibility to do this by using the macro could be a good ideia for the future.
Thanks for the answer. Unfortunately I don't have STAAD Pro license. But I'll try to model it mannualy.
