I want to place a stiffener on just one side of a W-type column at the point where it connects with 3 beams (see image).
How can I do this using the Stiffener Connection Tool?
You can just place the 2 stiffeners and delete one. The connection stays dynamic and even when you change the column size the deleted one will not reappear.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Answer Verified By: Fernando Borges
Johannes Michalowsky said:You can just place the 2 stiffeners and delete one
Simple. thank you very much. works fine.
