HI Guys,
Now we use Bentley prostructure to make model.
If some friends have the experience of import the IFC file in to the DIAlux for light calculation?
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip,
We have try, the IFC exported from Prostructure can not import in DIAlux.
If BENTLEY has a software can export a IFC can import in DIAlux and can work in dialux.
Hi Long,
OpenBuildings Designer is having a bi-directional interface with DIAlux, so you can send the spaces/walls/etc to DIAlux and get back the calculated luminaires into OpenBuildings.
You can find more info here:
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/20468/integration-with-external-mechanical-electrical-applications
Hope this helps,
Eduardo
Hi Eduardo,
Thanks for your information.
I will have a try.
