Has anyone experienced this issue? and a solution to fix it.
No dialogue box (Detail style) appear after right clicking on Detail centre and selecting create/edit Detail styles.
Thank you
Hi Dino.Thanks for raising your concern on the Bentley Community Forum.Are you using multiple screens? If yes, then this dialogue box might be opening somewhere on your secondary screens.To avoid this issue, please follow the steps which are mentioned in the link given below and let us know if you have any further concern regarding this.Link: https://communities.bentley.com/products/prostructures/w/structural_drafting_and_detailing__wiki/35891/dialog-boxes-off-screenRegards, Mihir PatilProduct Engineer, Design Engineering – Structural DetailingBentley Systems
Answer Verified By: Dino Crisostomo
For those with g-Force cards, nView only ships with Quadro cards.
To fix missing dialogues just activate the missing dialogue before loading a project. It is the project specific files dictating the current location of the dialogue. Once the dialogue can be seen on screen1, load your project, then close the dialogue which will save the new location for those dialogue boxes into the project.
This is the same for any floating dialogue.
If there is another way to get nView, I am eager to hear.
Hi Ian,Thanks for raising your concern in Bentley Community Forum.Yes, there is another way by which you can get rid off this issue. Please follow the steps below.1. Right click on desktop and open the nView Desktop manager.2. Now, Under the Windows manager, enable the option Prevent windows from opening off-screen.3. Also, in same dialogue, set the Dialogue Repositioning option as Move to application display.4. Another solution is, for PS CONNECT Edition, you can delete all the wnd files which are located at:\Users\<User name>\AppData\Local\Bentley\ProStructures\10.0.0\prefs\Personal_WndCfgThis sets all the dialogues to their default position.Please let us know if you need any further information regarding this.Regards,Mihir PatilProduct Engineer, Design Engineering – Structural DetailingBentley Systems
See also the discussion happened here
explaining the two solution ways.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
