Grid plate and frame layout fallow global coordinates not my local.
I'm trying to find settings to rotate manually directions or set local ACS as a main during creating platform.
Hi Mariusz, Thanks for posting your query over the Bentley Communities Forum. In reference to your query, we recommend you to use the Grid Alignment button in the Plates placement dialog box.
Please let me know if this resolves your issue. Regards, Alistair Lobo
Thank You for such quick response
It works for plates/polyplates fine, and had to be implemented during construction (can't be edited later)
But i would like to use it for rectangular platforms and use frame creation implemented in that tool.
so i won't be forced to create plate and than external and inner frame manually.
