How to import & export STAAD file in prosteel as i have STAAD Pro. v8i version.
Hi Ajay, Thanks for posting your query over the Bentley Communities Forum. In reference to your issue, please allow us sometime so that we and check on this. Regards, Alistair Lobo
Hello Ajay, You can export your STAAD model as an ISM repository to ProStructures and re-import it back into STAAD by using the Bentley ISM functionality. Also, you can refer the workflow video for Interoperability between ProStructures & STAAD.Pro at the link below - You just need to make sure that the STAAD.Pro, ProStructures and Structural Synchronizer versions are compatible with each other. For seamless performance and best information transfer process, we recommend you to use the latest versions of the CONNECT Edition of these applications. Regards, Alistair Lobo
Hii.... As i have mentioned that we are using STAAD Pro V8i version, in this version ISM option is not enable. Please suggest how to export the same for reference screen shot attached. .
Hi Ajay, Can you please confirm the exact version of STAAD.Pro V8i that you are working on. Regards, Alistair Lobo
Hii. Its STAAD Pro V8i (SELECT Series 1)
