I am using Prosteel Connect Edition Update 4 - Version 10.04.00.47
I use the standard detail center for detail drawings.
When trying to use drawing partlist command get message "only available in 3D"20046-MODEL.dgn
Regards,Sandip KarProduct Engineer - Bentley Systems
I did place partslist in 3D Design model. When i switch to 2Dsheet model the drawing partslist command does not work
Can you provide link or video showing procedure. My seed file folder does not have a 3D seed file.
