Hi Guys,
Can we do/produce Weld Mapping sheet/table for a certain shop/assembly drawing? e.g. Welds to have position marks/numbers then these weld numbers be listed? T.I.A.
you could include weld information via partlist.
Can you please place an example here for us for your typical look of report ? many thanks !
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hi Johannes,
It's something the below. Each fitting that needs weld would have the weld numbered and be listed.
Is it possible to give each weld an individual part number? Typically weld maps have a 'weld ID' which the inspector can use to identify the weld on his test cert.
It would be good to be able to produce a list&label report of welds per assembly with a weld number against each one
Hi Johannes/Mike,Has there been any resolution to this query?We are facing a similar problem and looking for a solution similar to above.
