I have created a IFC and a .bswx from the IFC, but when the fabricator tries to import it into Strumis it crashes.
Could I have some instructions on how to export files to be used in Strumis, just in case i'm doing it wrong.
Cheers
Regards,Sandip KarProduct Engineer - Bentley Systems
I am using Prostructures CONNECT Edition Update 5
is there a specific version on BIMReview/StruMIS required for the IFC intergration? I imagine that there have been changes to StruMIS software to enable the import?
Hi Mike,
There must be some Plugin from StruMIS to be delivered to make the IFC integration with StruMIS. We have sent thr message about this to StruMIS.
