The MicroStation version of ProSteel was released mid December 2008, but there are still a few differences between the AutoCAD and the MicroStation based version.
- selecting objects first - Drawings saved permanently - DGN format (we can NOT open the DWG directly) - no MDE
the interface. The dialogboxes, the workflow and the look-and-feel is the same:
We are working allready the "next" version of ProSteel on MicroStation. There it will be possilbe to have access to the programming interface (COM) of ProSteel, and then it will be possible to use all our COM based tools as well (Connection Center, Catwalk, Platform ...). Then both version have almost the same capabilities.
Gernot,
When should we be expecting the next release of Prosteel for Microstation?
Brad.
i am trying Prosteel v8i for Microstation and found the manual in Help Menu is actually for Autocad not for Microstation,
is there any updated help manual for Micorstation available?
thanks
Could you re-post the pictures? They seems corrupted.
