I have made the change from V8i to the CONNECT edition of prosteel and I have found that the drawing part lists are now changing width each time I hit the recalculate button.
The width of these fields are supposed to be set by the format values but its changing the width by a random factor.
Can you please advise how to fix this?
Hello Chris, Thanks for posting your query over the Bentley Communities Forum. In response to your issue can you please confirm the version number of the V8i and CONNECT Edition of ProSteel that you are upgrading to and from. Also, it would would be of great help if you could attach your V8i file so that we can better investigate the same. Waiting for your update. Regards, Alistair Lobo
HI Alistair,
The version of V8i we were running was ProStructures V8i v8.11.9.867
The new version of CONNECT we are using is ProStructures CONNECT v10.14.3.7
I've attached a CONNECT file for you to review below.
18001-____1.dgn
Thanks.
Chris
Hi Chris, Thanks for sending the file. I believe you have also logged Service Request # 7001140773 for this issue. Thus, we will carry on our investigation over the ticket and will communicate over that. Thanks for your cooperation. Regards, Alistair Lobo
Hi Alistair,
These are separate issues but happy for it to be resolved together if possible.
Chris.
Hi Chris,I can understand your concern regarding drawing partlist columns' width as it is a known issue. We were also able reproduce the same issue at our end too. Can you please log a Service Request for this issue?Waiting for your update.Regards,Mihir Patil.
