Good morning,
Is anyone else experiencing prosteel being especially slow and bogging down and lagging when you are moving about the model or using your display classes to turn your components on and off??
this is a very frustrating and i was wondering if it was happening to anybody else,
the computer in use is roughy 4 times high in spec that is recommended and should be more than adequate to handle prosteel, (we were running on older pc's before without this issue)
version: Prostructures V8i v8.11.9.867
Hi Benjamin, In reference to your issue, I think we may need to have a live session and check for the same. Can you please confirm your Email ID, city/country and time of availability. Waiting for your update. Regards, Alistair Lobo
No offence but i do not have time for a live session.
If there is a known issue with prostructures you should be able to tell me about it as opposed to wanting a live session, i also do not feel comfortable with sending you files
Hello Benjamin, My apologies for the inconvenience caused. In response to the issue you have posted, we have not experienced the same on our end as yet, and hence is not a known issue. Also under normal circumstances, this should not occur; unless the file is heavy. Regards, Alistair Lobo
