ProStructures CONNECT Edition Update 5 - Version 10.05.00.54 - Q: Key-in command not recognized (dimension size stroke). How do i fix this?
Not sure if this might be more of a MicroStation CONNECT Edition question, but at the risk of being a bit rusty with the forums these days, i thought i would post here.
In previous version of ProStructures V6, i was able to use a key-in command (dimension size stroke) which i attached to a custom tool for a custom toolbar.  Worked great too!  Working with smaller dimensions, it is very useful to have, and many other users in my office used it as well.  Now that we have migrated to CONNECT Edition (both MicroStation & ProStructures) i am getting the questions of how to fix this tool so it can be used, as it was before.
Any help?
Our current work-around is to just use the Linear Dimension tool and change the settings, but when creating drawings that use both formats (with stroke & with arrows - depending on location) it would be very time consuming to be switching back and forth.  Creating another Dimension Style has been talked about, but again that could create confusion.
I guess at the end of the day, the "ask" is, is it possible to get or somehow create the key-in we had before?  It worked....why take it away?
Thanks in advance for any assistance.
