Hi Bentley
1.Can you explain how we can add some new places to the drawings tables. I asking exacly for the Reserve fields. How we can add these fields in to the drawings table.
In the old version in Autocad all works, but in Microstation is problem. I prepered drawing frame and table with tags like in yours instructions, next created the cell and doesyn't works. Only some fields are visible in the drawings table - not all.
2. Maybe the reason will be when we use Items instead tags, but I don't know how that change in frm file.
1. First let to clarify what is directly transferred from Drawing Information table and what not. So lets consider following is the Drawing Information Table in 3D Drawing
2.And the outcome in 2D drawing
Green – directly from the 3d model drawing information table. Red – hard coded. Yes, that is new to me. Would be good to get some documentation from development here. Yellow – from the FRM file.
Now let me explain how Drawing Information Table reads the .FRM file
So there is only one option to fetch your Group Position no by using “DetailPosNumber” in .FRM file. You need to put your Tag directly into the .FRM file. However ther is no field available in Drawing Information Table, but your requirement will serve.
See also
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hello Johannes
That's means we can use in DC express only 20 fields, rest must be manually add to FRM file. Right?
So, can we change names of fields in FRM file for "Reserve" fields, to be the same how in drawing info table? (in lib file)
That will be no problem for PS to read this? That will be more easy for the users.
