Hi Everyone,
I've loaded the latest version of Prosteel for AutoCad 2020 and there's no toolbar menu at the top of the screen. The same thing happened yesterday when I loaded Prosteel for AutoCad 2019. Menuload doesn't solve the problem - the toolbar menu is still empty. Reloading of Prosteel doesn't resolve the problem. Changing the AutoCad version doesn't help either. And yes, the dll file and cuix file have the same names, which doesn't help.
Is anyone actually running the latest version of Prosteel in AutoCad 2019 or 2020? Can anyone help me out?
Hello Joseph Baran,
Thanks for posting your query in Bentley Community Forum. I can understand your concern.Can you please follow the following steps?
1. Type OP in command line to open up the options2. Go to File Search paths and delete the following paths
C:\Program Files\Bentley\ProStructures CONNECT for AutoCAD\AutoCAD 2019\PrgC:\Program Files\Bentley\ProStructures CONNECT for AutoCAD\AutoCAD 2019\Prg\Plugins
3. Type in Command line "Menuload" and load the ProStrucrtures.cuix file from the following pathC:\Program Files\Bentley\ProStructures CONNECT for AutoCAD\AutoCAD 2019\Localised\English\Menus
4. And then exit and relaunch the application.
I hope this will resolve your issue.
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip,
It did not work. The menu bar is missing still. The only thing that comes in, after following your procedure above, is the Prosteel Utilities Menu. Nothing else. I can manually add more Prosteel icons, but there's no predefined toolbar like there was up to now. Do you have any other suggestions?
you can try the command Ribbon. maybe they are off
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hi Johannes,
The ribbon menu command didn't help. I still have no menus and no way of using the program.
Also, another problem showed up with the Connection Client application, which hangs up my system or goes into a loop when the internet speed is slow.
I hoped the new Prosteel would offer real improvements, but as is, it's only an expensive headache.
Joseph
