Helo All,
During using "PROSTEELWERKZEUG_S6" tools for prosstel I have faced folowing problem.
Tools called "Bearbeitung" does not work properly, folding menu, shown below does not appear.
I have tried to change diameter of existing drillholes, unfortunatelly failed.
What may be a reason of that behaviour?
J.
We will send you a solution soon. Thanks for your request
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Please check your resource folder under the localised path, like:C:\ProgramData\Bentley\ProStructures V8i S8\WorkSpace\ProStructures\Localised\Deutsch\Resource
This folder should contain the ProSteelTools.rss file. If it is not in it copy it into this folder.Now the dialog should work properly.
Thanks for answer,
Unfortunatelly location C:\Program Data\Benley does not include folder Prostructures V8i.
"ProsteelTools.rss" is located there "C:\Program Files\Bentley\ProStructures CONNECT for AutoCAD\AutoCAD 2019\Localised\Deutsch\Resource" in my computer.
Is this a reason of the problem??
Janz
Hi Janz,
Which version of ProSteel you are using?Is it ProSteel for AutoCAD or ProSteel CONNECT Edition?
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip Kar
It is Prostructures for Autocad -connect edition, v 10.0.0.8 form nov 7 2019.
