Hello,I have recently updated to Navisworks 2019, AutoCAD 2019 and ProStructures CONNECT Edition for AutoCAD (10.0.0.8).Is there an object enabler to properly view AutoCAD/ProStructures 3d models in Navisworks 2019? New and old ProStructures 3D models are showing as wireframe in Navisworks 2019. Navisworks says there is a missing object enabler for "Pro_Stahl_3d". I have searched and cannot find one. Does it exist?
Regards,Sandip KarProduct Engineer - Bentley Systems
HI Sandip
is the 2019 OE backwards compatible with earlier PS versions?
thanks
Hello Sandip,
Thanks for the reply.I should add that I already have the PSCE OE 10.00.00.04 installed for AutoCAD 2019. I also have OE 10.01.00.02 for AutoCAD 2020 installed though I do not have AutoCAD 2020. PS objects are displaying but not shaded in Navisworks 2019 thus the missing OE reported in NW. It has all worked prior to upgrading PS, NW, AutoCAD and using the older applicable OEs.
My issue is now resolved. PSCE OE 10.00.00.04 has been reinstalled and I now see shaded PS objects in Navisworks 2019.
Thank you.
