Can someone please explain what are the 3 stars in front of the Group Position Number, in Detail Centre Express:
This is an indicator that something of the group is hidden. It could be by display class, level, hide command or whatever.
Help File:
In previous versions, the views or groups listed in the DetailCenter with " *** " would alert/warn you when one or more object(s) of a view or group are hidden and cannot be processed or updated.
Earlier, when one or more Steel or Concrete object(s) (this rule does not apply to rebar) either in the active view of a model or in a reference file are hidden, associated views or groups are then flag with "***" in the DetailCenter, alerting/warning you that one or more object lying within the ProStructures view or subpart(s) of a group are hidden and not visible, nevertheless they can be processed and can be updated, as you decide.
Only the following hiding methods to steel and concrete object(s) (this rule does not apply to rebar) are supported by the DetailCenter for views and groups drawing generation, all other methods are ignored:
It is important to note that for groups:
Active model:
Reference model (from within a composite model)
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Answer Verified By: lamensterms
Cool, thanks a lot Johannes.
AutoCAD 2017 - N 402.0.0 SP1.2ProSteel S6 - 08.11.11.207Australian LocalisationWindows 10 64bit
