Hello colleagues,
When I want to clone my general baseplate to another column - I am pressing this button.
After that - ProStructures asks me to choose an object.
And when I choose my second column - nothing happens.
Is it a bug or I am doing something wrong?
Many thanks for your request
Enhancement 1075868 was filed already :Clone option is not working for Extended Baseplate was filed. It will be fixed for upcoming release.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
To use the clone tool, you must first use the base plate tool on the new column.
It will use the last settings used. You can use the clone button and select an existing base plate to copy settings from
It will use the last settings used. You can use the clone button and select an existing base plate to copy settings fromTeam: jeephunter
In order to use the clone tool, you will first have to create a column of the same height using the base plate tool. This will copy the last settings used. You can also use the clone tool and copy settings from an existing base plate.
Source: Wellstations
Source-
