Hello!
In ProStructures Update 5, when creating a drawing, it is proposed to select "Drawing seed", but the usual "Section_Metric" are no longer there.
Is there a big difference in them, because at first glance, these prototypes are the same? Then why is it called "Concrete_Section_Metric"?
Picture 1 - Section_Metric in Update 4
Picture 2 - Concrete_Section_Metric in Update 5
P.S. I use default seed file.
Hi Ruan, Thanks for posting your query over the Bentley Communities Forum. In reference to your issue, please allow us sometime so that we can confirm and then answer you. Regards, Alistair Lobo
