Title says it all.
How do I book out a ProStructures license for use when I am off network?
ProStructures for AutoCAD 2016.
Hello Michael Kornbrekke,
Thanks for posting your query in Bentley Community Forum.
Now licensing is integrated with CONNECT Licensing which will ask you to loging in Connection Client. After login it will allow you to work for next 7 days and withing this period yo can work offline too. But after this 7 days period completed, you need to just once connected to your internet and again you can able to run for next 7 days. This is the way how CONNECT Licensing work. But if you always want to work offline then you need to Check out your license. Hope this has answered your query. We have here one Wiki which can explain you much better way.
Regards,Sandip KarProduct Engineer - Bentley Systems
Is that relevant for the earlier versions not using Connect?
you have to check out via the license manager as stated or see
as a similar case Nodelock checkouts. Just checkout from SELECT.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
