I have been using Prostructures, prosteel connect edition for a few months now. And today for some reason when I move the mouse these radiating lines slowly appear.
Not sure what they are or where they came from or how to stop them showing up.
They disappear for a small amount of time when I run the curser of them.
Any help would be much appriciated.
Hello Darren,
Thanks for posting your query in Bentley Community Forum.
The image you have shared with us is not clear and we cannot do much on this. Could you please share your DGN file if possible?
Also may I know which ProStructures version you are using? Are you using ProStructures for AutroCAD or ProStructures for MicroStation?
Looking forward to your update.
Regards,Sandip KarProduct Engineer - Bentley Systems
It could be a graphics driver issue graphics artifacts if you are working with the MicroStation version with an older card.
D: Create a New System Variable
For V8i versions, use enter:Variable name: QV_D3DVERSIONVariable value: 9
For CONNECT Edition versions enter:Variable name: QV_DISABLE_D3D11Variable value: 1
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hello. It turned out to be a graphic card setting. I turned everything back to default and it fixed the issue. Unsure as to exactly which setting caused it however.
Thank you for your help in this matter.
