I have just set up a new Laptop and installed prostructures with autocad 2016. When I initiate PS_DETCENTER the detail center window is not showing up on the screen.
Any ideas how to fix this?
Cheers
Hi Daff,
Thanks for posting your query over the Bentley Community Forum.
To resolve this issue, you need to delete all "*_WndCfg.sve" files from the below location.
For ProStructures V8i for AutoCAD: C:\Program Files\Bentley\ProStructures Ss6 R2\AutoCAD 20xx\Localised\English\Temp\Metric
For ProStructures CONNECT for AutoCAD: C:\Program Files\Bentley\ProStructures CONNECT for AutoCAD\AutoCAD 20xx\Localised\English\Temp\MetricFor more information on this, please follow the below wiki link.
Dialog Boxes Off Screen Product(s): ProStructures Version(s): V8i, CONNECT Edition Area: N/A Subarea: N/A Original Author: Johannes Michalowsky , Bentley Product Advantage Group… Last edited 4 months ago in ProStructures > ProStructures Wiki
Please confirm if your issue get resolves by the provided solution or not.Regards,Vyanktesh Nama
Kind Regards,Vyanktesh NamaSenior Technical Support Engineer Bentley SystemsBentley Structural YouTube ChannelBentley Technical Support
Answer Verified By: Vyanktesh Nama
Thanks. That worked.
