I notice if you have copied/multiple references of the same model in a model drawing view and then try Export > IFC only 1x of each copy gets exported.You can merge them into master and then Export > IFC but I think this defeats the purpose of being able to change 1x model and all change within.
Is there any other work arounds for this or future planned updates to have this available?Cheers
All I'm doing is File > Export > ProStructures File Types > IFC
Within a sub-model (a model modelled near 0,0,0) this works fine.Where it falls down is when you reference that model into a General Arrangement model multiple times, select all these models and then Export > IFC.It goes total bonkers.
